I'm finishing up the restoration of a 63 327-340hp motor and everything was going great until the starter was installed..The short block and heads were done by a reputable shop that's done all my other motors, and all the way up through setting the valve lash it turned over easily by hand.
Put it on the break-in stand, installed a stock style starter and it cranked slowly - barely enough to try and fire. I thought it might be a weak battery or starter and swapped those out. Seemed to get a little worse even. But the oil system was primed, timing was ok, none of the pushrods were binding, so I kept at it. Even tried a hi-torque DB Electrical starter and it actually took several teeth off my new Hays flywheel!
Today I tore it down in reverse hoping to find some interference - starter clearance, flywheel, balancer, timing chain, etc all fine. Scoped the bores - they look ok too. But rotating assembly will still not turn by hand.
Drained the Brad Penn oil and dropped filter, which looked fine except for some very fine filings on the tip of the dipstick (magnetic dipstick!?)
Any ideas before I pull the pan and drop some caps? Could the bores be too dry and seizing the pistons? Incorrect end play or thrust seizing the crank?
Its turned over maybe 50-75 revolutions max since all this started and never fired, so not much could have happened in that short time, I hope.
This is the first motor I've assembled that's ever had to come apart, and I'm a little embarrassed to admit it...
