I understand that with a stroked motor like a 383 for example there can be a problem with clearances between the rods and cam. This gets more prevelant with the longer the rod used. Right? Is the point of contact on the lobes of the cam? Apparently you can avoid excessive clearancing of the rod by using a small base circle cam, right?Can someone explain or better yet describe a small base circle cam to me. Are there any negatives using these cams other than maybe more expensive?
Thanks
Jerry
Thanks
Jerry
