Back in the old days, Im talking the early 80s my freind and I would look for 396 impalas, through down the 50 bucks and drag it home. At this point we would break out the gunk engine degreaser and start degreasing, this process would take about a month, after this was complete off came the heads, the call would be made to Herman Chapman for one of his valve jobs, the cam of choice was 240s @ .050 Schneider solid lifter cam sporting .540 lift. The heads would go back on with steel shim head gaskets of course. the finishing touch would be a edelbrock torker oval port intake (you know the one where the carb sits crooked) with a 850 holley, and not to forget the gold moroso valve covers. On to the drive line, a turbo 350 trans with a B&M shift improver of course set on the firm mode, backed up by a vega converter. Now what did all this 80s ultra low buck trickery net us young punks, well in a 67 chevelle we would get high 11s, but the learning was priceless. Back to today, I was buying some cores from this old codjer and to my suprise he had a virgin 396 4 bolt short block mint still with the steel shim marks on the deck, this brought back these childhood memories. My question to the forum is: should I buy it and put the solid lifter cam in it and 215 heads and the edelbrock intake along with the gold moroso valve covers and through it on the dyno?
