I am getting ready to start working on the frame of my 67. My goal is to get a smooth looking frame when i am done. There are some rough areas from rust so my approach is as follows. First sand blasting, followed by epoxy primer, body filler, high build primer, more epoxy primer and finally chassis black.
My problem arrises in the fact that i plan on boxing the frame rails but would like to spray the inside of the rails prior to welding them closed. i am not worried about what the inside of the frame rails look like, i just want to do what ever i can to prevent rusting from the inside out. would it be best to use a weld through primer on the inside of the frame rails or should i just spray it with the epoxy?
i have also seen the tube like attachments for spray guns that are supposedly for getting into tight places. Has anyone used one of these with any success? I believe Eastwood sells them. Any help would be appreciated. Thanks
