Hey all. This may have been covered before, but I have a question about the wiring of the 6al box. Situation is, I just installed a new engine wiring harness for my 69 chevelle. Realizing I got the non HEI, I made the necessary switch of the resistance wire to 14 gage wire. I now have the 6al in place and the wiring harness in place. I now just need to make the necessary connections. My questions are, what wire from the harness connects with the 6AL and where. And are the wires (purple and yellow) from the harness that go to the starter even needed anymore? The 6al manual states that it needs a 12v switch that is plugged to the thin red wire. Im assuming this would be the ignition switch wire? Which is the wire that originally would have plugged to the distributor? This is where im confused.
Thank you all in advance.
Tim
Tim
