I am going to change my 3.73 gears to 4.10 so my motor will be a little happier in .64 overdrive mode (shoulda got .82 with my cam...). If I had a pinion depth tool, press, yoke holder, etc, I would try to do it myself, but I don't have the time or patience.
I am going to remove it from the car and just take it in cuz I don't want to leave my car. And this way, I won't take the cover, so they won't be able to hide the pattern they end up with. Looking at the job, I think I need to:
1. Remove cover and drain the fluid.
2. Remove diff pin and remove the axles.
3. Remove the brake plates. Can I keep the brake lines attached and support the plates? I am just not excited about bleeding the system again after all the problems I had when I did the manual front disc conversion.
4. To make it easier to man-handle, should I remove the differential case? I can do that, I installed it. Plus, then I can install the ring.
5. Remove the drive shaft.
6. Remove the upper and lower control arm bolts. I'm very practiced at that after my UMI hassles.
7. all this assumes proper blocking under the axle and stuff, not just having it thunk on the ground.
Any other things to think about? The brake situation is my main concern.
