I've been searching around the forums about the 454 HO engine from gm performance and have been reading about oil burning issues. The problem is all the threads I have been reading are from 2002 and 2003 range. I would think by now that these issues have been fixed. From what I read it looks like the problem was with the cylinder bores. In any case I really like the idea of the 2 year warranty but will not buy an engine that I know has problems to start with.
I was also looking at the PAW 427 long block but after searching around here a little bit I found that PAW is not very reputable. This still true?
Sorry If you guys get asked this a lot about the 454 HO motor but I could really use some advice about it.
Thanks
Corey
Thanks
Corey
