I have a Comp Engineering 8 point cage from summit and after studying all of the past posts on the roll cage topic, I never did notice on whether or not I should use the plates that the kit comes with when I weld the bars to the frame.
I welded the bars to the frame, and cut the plates in half to cover the hole in the floor. Then used some sealer around the tube and the plate to account for some twist.I have a Comp Engineering 8 point cage from summit and after studying all of the past posts on the roll cage topic, I never did notice on whether or not I should use the plates that the kit comes with when I weld the bars to the frame.
Yes, this true. The unibody cars require plates, full chassis chevelles require it go to the frame.i believe the plates are only for uni-body cars. I believe its mandatory for them to be installed on them. Otherwise, you can weld directly to the frame.
I plan on staying with my stock buckets, but may go to kirkey's. I have not decided.Bends in the cross bar are typically OK. As far as main hoop placement, you want the plane of the hoop just behind, but not more than 6 inches from the back of your helmet when you are seated in the car. (that is specified in rules) If you have a thick seat back, like a stock bench or bucket seat, bend the cross bar to create the "pocket".
R/ Dave
I sent CE and email - still waiting on a reply.cmex, (Name ??)
Personally, I would think that bending a bar would make it easier to fail when needed the most. Before I did any bending, I would call CE and ask them, they are the ones that know.
