Only at start up, but not on all starts i'll get a pretty good burnt oil smell out the exhaust. After it runs for a couple seconds the smell goes away, opinions please !!!!
x2^.Are you sure you don't have a oil leak that is dripping on the exhaust system, and then burrnig off when started?
End of last summer, the heads were in the shop, i would imagine they replaced seals. It also blows white smoke sometimes on start up when i get the oil smell !!how old's the rebuild ?
Were valve seals replaced/installed ?
I've only noticed it standing at the back, coming out the exhaust !!Are you sure you don't have a oil leak that is dripping on the exhaust system, and then burrnig off when started?
