21 - 32 of 32 Posts
That car looks like #$%##, You need to give it up to someone who needs a POS (ME):D so I can fix all your mistakes and make it worthy of being a nice looking and functional car.........:D:D:D:D:D:D.....
Just kidding, Looks great keep the pics flowing:thumbsup: Oh and when you are done, go have a few:beers:
Discussion starter · #27 ·
thanks? here is what i started with
Sweet Car and Engine ;)
Hey i live down here in Stuttgart, Do you have any contacts capable of Bending/Installing 3.5" exhaust?
Good luck with the Project!
Btw- You have more duration than me ( lowering Dynamic Compression ) and I run around with 93 just fine. I also have a timing controller in the car so its easy to adjust timing if I get a bad fill of gas....
Discussion starter · #29 ·
thanks alot man! i called one of the guys that does custom exhaust and he cant bend it but he can order the bends and build a nice set, and there are a few places in the tulsa area that can bend it, pm me if thats not to far and i'll get some more info if your interested!
Thanks,
Using a box full of Jbends to make it would be fine too. I just cant weld worth a crap. I wanted to buy a X Pipe section then just get someone to connect it ( using various jbends is fine ) to the headers up front and a set of UltraFlows out back. I really think my exhaust is holding me back.......
http://www.torquetechexh.com/gmaheader.htm
Check this site out for CNC Mandrel bent tubes. He carries pipes up to 3.5 inch for the GM A and G bodies. Notice: No crumpled ,crimpped, mangled pipes. All nice neat smooth bends. Very high flowing pipes with excellent quality. Only comes in mild steel or aluminumized coated mild steel. No stainless offered.
21 - 32 of 32 Posts
