Getting closer to finishing this Chevelle but I am a little stumped on this. The left and right turn signals work with the headlights or parking lights off. Soon as I turn the parking or headlights on the right turn signal quits working or goes extremely slow. The left continues to work. It seems the left flashes faster than the right with the parking or headlights off. The hazards work fine with the parking or headlights on or off.
I tried the usual going around the grounds and cleaning them up a bit. Also using a temp extra ground wire to make a better ground. I can manually flash the blinker and it works.
