if an engine has low vacuum, is it possible that it will it not open the secondaries all the way?
i know all too well about those springs...ive been changing them and playing with the check ball for weeks now to no avail.On a VS carb, there is a spring that determines how quickly (or if) it opens. As said above, not dependent upon engine vacuum - but it is very possible the secondaries are not opening fully.
Good point - check the screws on the bottom of the carb holding the baseplate to the main housing as well. I'm not sure of all the circuitry, but you might have something else going on that's affecting it.Make sure that the vaccum housing is air tight = diaphragm isnt torn or somehow leaking
rebuilt carb. it has all the gaskets and the diaphram is perfect. the carb looks great inside and out. im totally mind boggled when it comes to the lack of performance of this car.Good point - check the screws on the bottom of the carb holding the baseplate to the main housing as well. I'm not sure of all the circuitry, but you might have something else going on that's affecting it.
Was it a new carb? Rebuilt? Unknown history?
yep. im going to try that once i get the carb back together.Mike..are you familiar with the paper clip test?A micro switch would be better..but it is an old school technique that works.With the engine shut off,place a paper clip on the vac sec link tight to the bottom of the dashpot.As the secondary rod lifts on a full power run,the rod will slip thru the paper clip and then return to closed.Shut off the engine and then manually open the secondarys until the paper clip again contacts the dashpot.You can now view down the throttle bore and see how far your secondary blades rolled open.Hope this helps.
