Since I finally have my convertible back on the road, I thought I would update this post. I ended up going with a Holley 4492 carb (restored thanks to Eric at Vintage Muscle Car Parts :thumbsup: ) on my fresh 454. I'm very pleased with how it runs. The Lunati 60204 is a little low on vacuum at low idle for the power assist brakes but I can live with that. Overall it performs very well with my combination. Since the motor is still getting broken in, I haven't thrashed on it extremely hard however for a '70 convertible that I drive quite often, there is more than enough motor under the hood to draw attention to the car! It has nice lumpy idle and sounds great via the Parts Place Inc. reproduction dual exhaust. I'm going to need new rear tires soon! :thumbsup:
Build Specs:
454 .030 over
Factory steel crank
SpeedPro Hyper-tech pistons with .100 dome mounted on thumb-rods
Stock 291 heads
Winters 569 (LS6 / L78) intake
Holley 4492 780cfm carb
Factory cast-iron exhaust manifolds (non-functioning A.I.R. system coming soon)
Lunati 60204 (with the corresponding valve springs)
Turbo 400 (slightly massaged with auto-shift or full manual)
BTE street/strip converter
4.10 12-bolt posi
