OK..my signature shows my car specs.
I running MT ET Streets that are 27 x 10.5.
I have been running around 16 lbs of pressure, but the inside and outside where wearing bad. I have made different increases all the way up to 22 lbs and have not noticed a better result in traction.
Hear is what I have notice. My right rear quarter panel has very little rubber on it, where as the left rear a good amount. The right rear seems to stay cleaner on coming off the track whereas the left gets alot of gravel. The right rear also has a soft rubber build up on the outside rim of the tire.
I'm using the Hotchis springs which aint that great for racing.
Any ideas?
Any ideas?
