hey guys im new to the board thought this might interest u .my new engine dynoed just yesterday.
engine is 540 bbc on pump gas
gm 502 block gen 5 bored 4.5
4340 scat stroker crank 4.25
srp pistons 10cc domes measured for 10.6.1 comp
edelbrock victor 24deg alloy heads 340cc intake ports
shaft mount yella terra 1.7.1 roller rockers
merlin single plane 4150 intake
carb is a quick fuel 1050 with annular boosters 4150 holley engine is pulling 2 inches of vacuum on carb so shes sucking hard on that carb may need slightly bigger carb and intake maybe?
solid roller crane power max cam part no:138781
duration@50 246 254 lift 615 636 with 114 lobe centre
srings recomended 190lbs closed 488lbs open
min rpm 3200
max rpm 6800
valvefloat 7400
crane solid roller lifters part no:13519-16
ok dyno results
max hp 646 @6000rpm
max torque 677.8 @4700rpm
this will go into full weight 73 camaro that will be street driven with trips to the drags and car shows with th400 manual shift 9 inch rear 3.7 gears and 4000 stall converter oh and there is also a gear vendor overdrive backing that all up.
ok my comments on my own engine is i think the cam is a little small and would rather have around 700plus horse power but my engine guy says this will give good street manners but it seems to me 700hp plus with street manners should be do able on pump gas seems like every one else here has 700 plus hp.
so what do u think
min rpm 3200
max rpm 6800
valvefloat 7400
ok dyno results
max hp 646 @6000rpm
so what do u think
