Hi Guys.
I'm going to do a total new front end job on my 72 Chevelle Malibu.
I've found all the parts I believe I need to get the job done from (Ground up ). With the Deluxe suspension kit plus upper & lower control arms the site give's me a choice of oval or round bushings? Not sure on which to use here? I Also want to replace the shocks on the front while we're at it.
Any suggestions. If you want to see the (Deluxe suspension kit) plus (upper & lower control arms) here is the link to both at ground up.
Upper & lower Control arms
http://www.ss396.com/mm5/merchant.mvc?Screen=PROD&Store_Code=chevellecamino&Product_Code=KAL-KIT
Deluxe front end suspension kit
http://www.ss396.com/mm5/merchant.m...merchant.mvc?Screen=CTGY&Store_Code=chevellecamino&Category_Code=SUSPENSIONKITS
thanks
Al
thanks
Al
