I am having a hard time removing a rear main cap from a Gen V BBC. I am using a rubber mallet, but it is not budging.
E Elcoman · Registered Joined Dec 5, 2002 · 5,630 Posts Discussion starter · #1 · Jan 31, 2008 Only show this user I am having a hard time removing a rear main cap from a Gen V BBC. I am using a rubber mallet, but it is not budging.
6 65lkey · Registered Joined Dec 20, 2007 · 2,252 Posts #2 · Jan 31, 2008 Only show this user try wrapping a rag around a screw driver and but it in the bolt whole and GENTLY hit it and see if you can get it to come loose
W Wooderson · Registered Joined Jan 29, 2001 · 1,244 Posts #3 · Jan 31, 2008 Only show this user A plastic or wood hammer should work better. Rubber will absorb too much of the impact.
E Elcoman · Registered Joined Dec 5, 2002 · 5,630 Posts Discussion starter · #4 · Jan 31, 2008 Only show this user I got it. I used a screwdriver in the bolt hole, then after it was loose I used a tiny prybar to break it from the silicone on the rear main seal. Thank you guys for the fast responses.:beers:
G Guest · #5 · Feb 1, 2008 He, He!! Easy, a light tap w/ a 3# Ford Tool!! He, He!! Glad you got it off. pdq67 Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
