Hey guys, I may have the opportunity to score a 454 block in the next few days. I currently run a 414 BBC, but I wouldn't mind having a few more cubes. My budget is rather limited, so I will be swapping over the cam, heads, intake and carb from the 414. Tell me what you think.
Currently on the 414:
Performer RPM manifold
Holley 3310 VS
Summit HEI distributor
Comp 292H, .550 lift on both sides, 244/244 duration at .050. 110 LSA.
290 closed chambers. Unshrouded valves (2.19/1.88). Fair amount of portwork done, nothing extensive but good amount.
Hooker Comp headers
3 inch Pypes X pipe system with cut outs.
TH-400, 10 inch 3000 stall converter.
3.73 gears
Holley 3310 VS
Hooker Comp headers
3.73 gears
