Ordering a crane cam, should I get the matched lifters? Or is there something better? Just curious, used to have a set of rhodes lifters. Always thought they were pretty good, are they still around, can't seem to find them? Dave
=Originally posted by Rich-L79:
Just to horn in a bit on this thread. Are the lifters with the .021 hole in the sole worth the trouble to keep a steady supply of oil on the lobe or is it simply overkill?
I have those lifters too and noticed a drop in pressure. Didn't know it was attributable to the lifters.Originally posted by bluerebl:
Is it a good idea to run a HV/HP oil pump when using the microlube solid flat tappet lifters?
I am seriously considering them in my sbc 406 project. The cam I'll be using is a Lunati/Ultradyne grind with a decent amount of lift and duration.
