My 396 has always ran "hot". It is an oval port, edelbrock dual plane intake, hydraulic non-roller cam .515 lift 280 duration, headers, q-jet, crane cams electronic ignition. I replaced the 3 core brass/copper radiator with a 2 core aluminum. It used to run hot on the highway. Now it doesnt run hot at highway speeds but still runs "hot" at idle. By hot I mean 15-20 higher than thermostat.
In an attempt to see if timing has anything to do with it I pulled the vacuum advance line and plugged it, the timing is about 12 advanced. I plugged the vacuum advance back in and the timing did not change. Vacuum advance is connected to the front bottom passenger side port of the q-jet.
Also the q-jet idle screws have almost no affect on idle until they are almost completely closed. I have noticed this issue before, thought it might be worth mentioning here. Also when I back it into the garage I can usually smell gas after shutting it off, as if some fuel is passing thru without being burned????
Also have thought about upgrading to an aluminum high flow water pump to help with the cooling.
Weird thing is, it runs great. Idles smooth and the 4 barrel comes in smooth and rapidly, no bog or pinging. Just seems to me something is wrong.
Anyone have a suggestion on what to check, fix, or adjust.
