Re: Is a good synthetic oil as good as a high zinc content dino oil with a flat tappe
RICH,I JUST COPIED THIS FROM PERF FORUM;
VR1 Racing Oil isn't the oil we thought it was
This is from valvoline web--
1-Valvoline Conventional Racing Oil is designed for racing application only. Its unique formulation contains premium mineral base stocks and advanced additive technology to reduce internal friction and help enhance horsepower output. Available at NAPA.
Designed for high-performance racing engines
Proven to provide more horsepower than the most widely used engine oils in grassroots racing
Helps increase horsepower through advanced friction modifiers balanced with reduced detergent levels
Contains increased amounts of zinc for extra engine protection
Not for use in wet clutch applications
Racers — whether weekend warriors or committed professionals — are always looking for a performance edge. Drawing on over 100 years of racing heritage, Valvoline has developed a new line of conventional and synthetic racing lubricants formulated to increase horsepower and protect high-performance engines. Though these special formulations have been developed only for grassroots racers (not for street use), Valvoline's VR-1 Racing Motor Oil has been reformulated to meet all new-car specifications, making it the right choice for the track or the street.
2-VR1 Racing Motor Oil's exclusive chemistry is designed to reduce friction and enhance power. It is among the most popular engine lubricants in all types of racing including CART, stock car and drag racing. It is recommended for engines burning gasoline and full or partial alcohol fuels in track and street service.High performance and protection for today's engines that run at high RPM
New ashless anti-wear additives combined with ZDDP provide ultimate wear protection
Enhanced anti-foam system helps protect the engine even during extreme stress
Enhanced additives protect against high-temperature deposits for a cleaner engine
Friction modifiers help improve horsepower output.
3-Valvoline Synthetic Racing Oil is designed for racing application only. Its unique formulation contains premium synthetic base stocks and advanced additive technology to reduce internal friction and help enhance horsepower output. Available at NAPA.
Brett
