I’m in the middle of a freshen up of my engine in the Chevelle. I’ve been running the Comp XR286R solid roller for a long time. I see guys on here running fast ETs and making a lot more power than I am while using hydraulic roller cams. I can get a HR cam with similar duration numbers as my current solid but I realize there is much more to that. Like the ramp rates and area under the curve.
Keeping my compression the same while improving my heads slightly (new 11/32” valves vs the original 3/8” valves and a complete valve job) could I make the same or more power with a hydraulic roller while having a bit more reliability and no lash concerns?
