1 - 20 of 39 Posts
Chevelle SS 396/375
1967 Chevelle SS 396 L78 (Sold in 1970)
I have a few questions for you Rochester/Carter Quadrajet gurus:
First off, I apologize for the length of this post, however the more I studied this issue the more I learned, and reviewing old posts on Team Chevelle REALLY helped, in addition to my reference books.
I am going through my 1967 Chevelle SS 396 325hp Engine (Non A.I.R.) with TH400 that I bought in November 2022. Mostly original car, original engine in the car (I doubt it’s ever been out of the car. At some point the car was obviously refreshed with new paint (well done), and I’ve been going through the engine parts codes getting familiar with it. It has an ungraded HEI Distributor, but I thought everything else was original, until I looked closely at the Carburetor.
Now, first of all, I’ve never been a fan of the Quadrajet, preferring Holley Carbs like my old L78 Chevelle had….zero issues with the Holley! I know from experience that Quadrajets can be temperamental and difficult to tune properly, especially the early models. Maybe my car had a temperamental original Quadrajet from the factory?
I did some research, and I believe the correct carb for the 396/325 A/T with no Smog should be Part Number 7027216 4MV (but I’m not certain..please see below)….I know the early versions in ’67 were plagued with problems…likely the original Carburetor for this car was an earlier version. The car’s build date was May 19, 1967 (Atlanta Build). The Engine was a Tonawanda build with correct numbers, with assembly date of May 10. I couldn’t see the casting date on the block but the part number is correct, as well as the stampings on the passenger head. Based on my 1967 L78 Block there is about a month between the casting date and the engine build date in Tonawanda, so I am assuming the casting date may be in April (but not really important).
According to my Chevrolet By The Numbers book, 396/325HP A/T w/o A.I.R. (3rd Type) would be p/n 7027216 (as mentioned above), however that model may be too late for my car’s engine build date (not certain like I said earlier).
Therefore, the other two models would be:
p/n 7027200 (Early)
p/n 7027210 (Late)
396/325HP A/T w/o A.I.R….for all three models I am considering.
Well, after finally getting into what carb is actually on the engine (the original manifold is still on the car) the engine appears original with correct p/n’s….original orange paint even. However, the carburetor is stamped Made In USA, but it’s a Carter built Quadrajet, not a Rochester. The p/n is 7029202 with accompanying A9 and DH Stamps. Looking this p/n up shows the carburetor as being 350/255 300HP A/T. This would be a 1969 Carb built by Carter. This p/n in the book is shown as 7029202 4MV. My engine does indeed have a divorced automatic choke assembly, just like my L78 did with the Holley.
I have read that when demand was high carburetor builds were farmed out, Carter being one company. I also read that there were problems with earlier Rochester Quadrajets, so many were likely replaced under warranty by factory replacements. Later Quadrajets corrected certain issues with earlier models, especially regarding the plunger-style fuel valve and secondary-air- valve dash pot assemblies (per the book: How to Rebuild and Modify Rochester Quadrajet Carburetors by Cliff Ruggles).
So, my questions are (based on the above):
1. Could this be a factory warranty replacement, although I am questioning the part number? If it was however, I doubt the carb would present as well as it does. Looks too clean, but it does show some wear. See pics.
2. Can the performance of these carburetors be manipulated by simply re-jetting, etc.? Could my carb be the same spec. as any of the above referenced part numbers for 1967 by simply re-jetting or otherwise modifying it….by a previous owner or mechanic?
3. Is this definitely the wrong carburetor on this engine? If so, even if it ran great, I would change it! It’s the only thing that isn’t numbers or date correct for the assembly date of my car and engine. I see the carburetor as a normal maintenance item, like if the original carb wasn’t functioning well, the best thing to do was simply remove it and put on a more reliable carburetor!! I’m fairly certain this is likely what happened. And, possibly, the person doing the work didn’t care or didn’t know that this carb wasn’t spec’d for the Big Block, but a Small Block.
4. I may simply get used to driving it with this carburetor while I get used to it, and address other items like rebuilding the original radiator (it has a slight leak).
5. Any recommendations where I might get a date correct Quadrajet for my engine build date of May 10, 1967? By reading through old posts on this forum, I saw where someone mentioned that the stock carb for the ’67 Chevelle SS 396/325HP Engine was p/n 7027201 for the Manual Trans Cars and p/n 7027200 (Early Version) for the Automatic Trans Cars. Now, with my car’s engine build date being May 10, 1967 wouldn’t my engine likely have had the Late Version (or p/n 7027210?).
6. So, which of the above referenced part numbers that I listed for my 1967 engine/transmission design & build date would be correct to look for? 7027200, 7027210, or 7027216?
7. Finally, where do I look for one? I’m not really interested in having a totally restored and replated example as that can get expensive, and would it have the best internal in it anyway? In other words, can a freshly rebuilt carburetor be assembled with the necessary upgrades being included thus eliminating the prior design flaws?
I would be more than satisfied continuing to use what’s on there now, but the way the car starts and the automatic choke operates presently isn’t all that great anyway. Once totally warmed up it’s fine, but it reminds me of why I hated Quadrajets back in the day…temperamental! I know these carburetors can be just fine and tuned for more performance, etc., but I really want my car to have the correct code carb on this engine. It’s no hot rod but shows very well as an original example…not a ton of them around these days! I just want it to start easily and idle and drive well!
Thanks for your help on this.
John
Reach out to Eric here on this site.I'm not 100% sure of his business name"Vintage muscle car parts&carbs? Allstate is another source. Just have to ask,how does it run with the 350 carb? I would think that the right carb will be expensive.
Like I mentioned, once warmed up it seems to run fine and whoever installed it appears to have done a good job, but when cold it will die if I don’t sit there and rev it for ever it seems. The thing I’ve never liked about automatics is the choke issue. On a manual car it’s much easier to feather the throttle to keep it running when cold. I’m just not used to it and don’t like it frankly. We all must remember these cars are old technology sure, but that’s no excuse to have to live with a stumbling carburetor in my book!
Thanks for the referral!
Reactions: magicrat56
Discussion starter · #7 ·
I put just over 80,000 miles on the Rochester quad on my 67 SS 396 Chevelle, in two years with a little chemical cleaning and slight tuning. Here is a friend and our cars in 1967.
Nice! When was your engine built and which part number is on your carburetor? I’m assuming your 396 is the L35 (325HP). I can tell those Chevelles are new or not old because the grills look correct!
The picture was the summer of 1967, and both cars are long gone, with a new 383 4spd 69 Hemi Orange Super Bee replacing my two-year-old Chevelle (bad tradeoff in retrospect).
Discussion starter · #9 ·
Hindsight hurts sometimes. I sold my new '67 3 years after I had it delivered in the summer of 1967. Sold it in August 1970 (gave it away) due to the draft during Vietnam....sad time! I've always wanted another one, and I finally bought one in 2022 for "ALOT more $" than my '67 Chevelle SS L78 car cost new! Times change for sure. Wish I still had my first Chevelle too! Great car!! Of course that one had the 780 CFM Holley on it so I never EVER had any carburetor problems!
Discussion starter · #11 · (Edited)
I'm still hoping that someone with a similar setup on their 1967 SS 396/325HP Automatic might be on the forum who can let me know for SURE (or at least within logical reason) which carburetor came on my car in all likelihood (based on their build date). I'm doubting the 3rd Version Quadrajet (p/n 7027216) was on there as those were only used on very late builds, but maybe a 3rd week in May would be late enough?
I doubt the carb on my car new was the early version either (p/n 7027200). In all likelihood the Quadrajet that came on my car when new was the second, or late version (p/n 7027210).
I suppose it may vary from Assembly Plant to Assembly Plant back in 1967, but I'd think I could be "close" with enough research and input from owners.
From what I've seen thus far a completely rebuilt Quadrajet is very pricey, if I can even find the right one! So, if I go that route I want to be certain I am targeting the correct Model.
More input would be welcome on this.
With your cars late build date, it would take a 7027216. The 7029202 you have now is a `69 350/300 A/T 49 state carb.
The most commonly utilized "one size fits all" replacement Qjet is a 7029207 which is a `69 350/350 HP Corvette carb. GM offered this as a service replacement at least until the 1980's if not later. You could consider it the "Holley 3310" of the QJet world, they run great on damn near anything.
If you're going hunting for a real 7027216, be VERY wary of previously restored carbs as there are a lot of bogus re-stamped shitpiles out there. A shiny carb does not necessarily mean it's going to run right. Your best bet is to hold off and try to find an original un-restored unit and have it gone through by someone who knows what they're doing. QJets are an entirely different animal as compared to a Holley.
Discussion starter · #14 ·
Can't you change the one you have to the settings you need?
Well, possibly but I’m learning. I’ve wondered if the jets could be modified to match the correct Model Carb. This is why I’m asking for advice. I can live with what I have if I know it’s as good as or better than what should be on there and can be setup to idle and run well. I may play around with things a bit now that the weather is warmer.
I did find a rebuilt 7027210 Rochester Quad with correct date, but it’s $1,100! I just need to be certain what I need to be correct for my original build, but obviously having the better upgraded internal parts.
I could live keeping the one I have because it appears to be in good condition but I have reservations the way it starts and warms up.
You should pick up Cliff Ruggles book on Q-Jets and learn some of the tips on tuning them,your only issue seems to be with the choke. If you look at the above add it's a generic rebuild that covers many applications. You can see how expensive the right carb can be,so unless you could find one untouched legit carb you can get the choke to work better.
Discussion starter · #18 ·
I have that book already....just starting to learn however. It’s already paid for itself! The correct p/n rebuilt carb I mentioned above is actually not $1,100 but $1,245! Yikes! I agree my Carb’s main issue appears to be the choke! It just bugs me my Quadrajet is for a Small Block but it sure looks the part! Not much difference at all so far as I can tell.
I have a mid 70's 350 truck Q-jet on my 468,like I said,you can make them work. With your choke issues,is the heat-riser working and is the intake getting hot under the choke stove? One last thing is there a stainless steel gasket under the base gasket?
Judging by your pictures I would think that this carburetor has already been to a rebuilder. If that is a 69 carburetor someone has changed the choke plate to the earlier style like a 67 would have, 69 is different. Your idle problem might be just a fast idle adjustment. When you open the throttle the choke closes it pulls up a cam on the passenger side and this holds the throttle blades open a bit more than what you have the idle set at and is adjustable with a screw. Pita to get at but it’s there. When it warms up the choke opens and the cam drops out of the way and your back to your regular idle setting.
1 - 20 of 39 Posts
