I picked up a raised cam Motown block which takes a BBC cam core, disregard the small base circle.
We're gonna put this engine in the Third Gen Camaro to run it through its paces 1/8 mile, hopefully before the third week in May. When slow conditions hit in Florida.
If you were gonna make a educated guess, what will the Third Gen Camaro run at 3150 lbs w/driver, 18 degree (3.875 x 4.185) 10.5:1 pump gas 427 sbc 1/8 mile n/a, with Straub / Mayhem max ported heads, with this Lunati custom solid roller camshaft, Scat counterweight crank, Scat H beam rods?
I've got a handful of torque converters and gear ratio's to cross at 7800 rpm's. Probably shift 7200-7400 rpm.
If you have a better idea for a camshaft in the 70's for overlap, post its specifications. I'm considering all true hot street car camshaft options Lunati or Bullet Cams.
