Hi guys, looking for input on hooking up a vacuum advance. I'm running a GM HEI on a freshly built 462.5 approximately 500 HP, with a TH400 2000 stall. Currently I run it at 36 degrees all in, 16 base, without a vacuum advance hooked up. I drive primarily on the street, no racing or drag time. I'm in the process, waiting on parts, to hydra boost the brakes due to 12Hg vacuum at idle, 800 RPM in gear. 3.31 out back with 28-inch tires. I know a vacuum advance might increase the MPG used, which would be a benefit, but not sure my setup would benefit from it. My engine builder said no, he races BB's. I have a Vacuum advance limiter installed that should only give me an additional 10 degrees advance, but never hooked it up to the vacuum, following his advice. I know about the try it, if it pings, retard the timing aspect, but I have to admit, my confidence isn't high enough to try it. Zero decked 22cc domed pistons with 781 heads shaved to approximatly16cc chambers, about 10:1 compression, 104 octane. What say you? I'm not a wealthy man to rebuild an engine again but for the same reason some MPG would be a plus.
