21 - 28 of 28 Posts
I have had to many complaints on Morel HYD lifters and have switched to Johnson Lifters, Much better quiet and you can adj. 1/8 of a turn, Having to adj. and HYD. lifter one full turn is not a good deal if the you float the valves.
The Extreme Energy HR and SR cams I owned were the quietest cams I've run - go figure
I would stay away from Comp Cam products.
I would use the best roller lifters on the market, which would be from Isky or Crower. Needle bearings are a bitch to remove from an engine. If you can afford them, both brands offer needleless roller bushing lifters.
It's also important to get the on seat and open valve pressures to match the lifters.
This!!! One day people will learn....every cam, lifter etc I tried over the years failed. All of em.
Look at theissues the ls guys had with theirs wow thats just crappy qc. Giants get that way from cutting corners on you and marketing more...putting catchy names on stuff to sell it
Stay away from real fast ramp cams its not worth it.
Isky/Crower fan also
I think it's more like cheap chinese steel.
21 - 28 of 28 Posts
