The mini-starter on my bbc will bind about every third time I start it. Today it wouldn't disengage from the flex plate. I loosened both bolts and got it to retract. The flex plate is tight. There are only two bolt holes in the starter. It was tight. I've tried shimming the inside, then the outside bolt, then both bolts with no improvement. Looking at the flex plate the very edge of the teeth facing the starter are wearing off. The starter and flexplate do not appear to be mounted parallel to each other. I've never noticed that before, maybe it was just the angle I was at. I've hopefully attached some pics. Appreciate any thoughts.
