Inside that end of the z-bar there should be a white plastic concave washer then the ball stud then another white plastic concave washer then the snap ring. Now there should be a felt washer in between the end of the z-bar and the frame mounting bracket. On the other side of the bracket I normally put a flat washer first so the lock washer doesn't get caught in the slot of the frame bracket and then the nut.
