I got a new sending unit today. I tested it and got basically the same readings as found on my old unit though I do not see the needle on my multitester bouncing occassionally as with the old unit. The ohms do not measure up to the ranges listed by Dave in my earlier thread. I now have to wonder if my multitester is out of whack. A new battery in the tester made no difference in the readings. I'll stop by Radio Shack tomorrow to compare it against a new one.
Assuming the sending units are okay, and since they both read basically the same I now think they are both okay, I'm left with a bad ground at the dash or a failing gauge. Who can I contact and how can I contact them about repairing the gauge if it is indeed the culprit? If I measure the ohms from the sending unit wire at the engine to a ground it is a very low reading (under 100) so I believe the wiring and ground are okay, again that leaves me with the gauge itself. The full open/full closed test of the gauge seemed to show the extremes on the gauge I would expect and while that confirms the connection is good it does not necessarily confirm the gauge itself is good (right?).
Why can't it ever be the easy solution?!
