I am at wits end here and not sure what else to try. It was doing this with the old engine combo and now the new combo. Today was the first test drive. Everything went flawless except for the temp not wanting to stay around 180 to 190. It was 60 degrees today. It hung around 180 for about 5 minutes of cruising then slowly went to 190 then slowly to 200. When I got back to the house it was around 205 and I let it sit and run and it creeped up to 215. I checked the fans and they were running but they were not ramped all the way up like I was expecting to find.
I am starting to wonder if this thing is giving some kind of false reading. I need to get a thermal gun and get some actual readings. Here is every last detail about the cooling system. If anybody see's anything that catches your eye let me know! Maybe I need to step down to a 160 and set the controller to come on at 170 so by the time it gets to 190 to 200 it will be running full blast.
Ready rad radiator that a lot of people on nastyz28.com use. One guy is in las vegas with a 496 powered camaro that runs high 9's and he said this same radiator keeps his engine nice and cool.
Spal's baddest of the bad twin fan setup. Over 3000 REAL cfm, fully shrouded and it has rubber flappers that open up at cruise speed to allow proper airflow while cruising so it wont dam up. This thing will suck a small child through the radiator. http://www.spalusa.com/store/main.as...&item=30102130
Delta current control FK-85 fan controller. I lowered the "on" temp to 190 (was 200 and they claim it comes set from the factory to work with a 180 thermostat). It ramps up speed as it needs it but even at 215 it is not ramped up to full speed. Put the probe in hot water and it will go to full speed but not when the probe is in the radiator? http://www.dccontrol.com/constant_te...ontrollers.htm
Stewart stage 1 high flow water pump
Timing is all mechanical. 27 initial and all in just before 3000rpm set at 37 degrees total.
Stewart/Robert shaw high flow 180 degree thermostat. It has 3 holes drilled as a bypass and to allow trapped air to escape. I have tested it and it opens right at 180.
Upper and lower hoses are universal hoses with the steel spring in them. They can not collapse.
Cometic head gaskets with modified cooling. Block was drilled to accommodate the modified cooling.
Autometer temp gauge. Tested along side the thermostat and tested right on the money.
I am really starting to think the thermostat is not fully opening causing reduced flow and the slow rise in temps. I am going to go grab a standard stant super stat today for the heck of it and see if that helps any. Stant claims that it is a heavier duty higher flowing thermostat than there regular $4 thermostats.
