N
B2070
3955287
It was 20FEB70 date. is it possible they would of still used this on a 1971? Thanks guys!
Thank you guys I talked to Eric, he seemed to think it might run different depending on engine set up as mentioned above. I ended up ordering one with the right number just because im OCD lol it does have the matching engine and transmission in it. I do question the intake manifold not sure if they would of used it on the engine or not the casting number isBack to your Qjet. Very likely replaced somewhere along the way with an stock off-the-shelf rebuild, which would likely have truck numbers. That's OK. I know one of the carbs Eric did for me was off a motor home ( from Tom mobely ) and the other maybe a md 70's something or other. The RV one is800+ cfm, while the 70s small block Camaro is a standard 750 cfm version.
You COULD try to find the correct casting #, and again Eric is a restoration pro, so may be able to help you there as well.
PS I decided not to run either, but I really ogth take a shot of the one Eric restored. I don't wear jewlery, but that thing is uber bling! in an OEM way. Just friggin' stellar finish. Reminds me to do that.
If the carb seems to run fine, run it! As long as Qjets dont get too much fuel pressure, once in tune, they do tend to remain that way.
B2070
3955287
