Carb selection will really be determined by the engine requirements... based on any modifications (cam, headers, intake, etc)?
"2.9" valves you say?? Is that a metric measurement of some kind? Because there sure is no such thing as a 2.9" diameter intake valve. At least not on any Chevy engines. Unless you weren't speaking of the valve diameter.109.4 CC semi open heads with 2.9 valves.
Yep, that must be the case.I think the OP meant to type 2.19" valves![]()
Probably need it out them off anyway and look.The next time you have the valve covers off for some maintenence there is a number for your cylinder heads that is casted in about the center of the cyl head. Having the casting number will tell you what the valves were when they brand new but if they were modded who knows ???
Typically Big block Chevy heads with 2.19 intake valves would have 1.88 exhaust valves but if the heads were machined for larger valves the exhaust valves could be anywhere from 1.72 to 1.88.
That's a very broad and misleading statement. The majority of OEM oval port passenger car BBC heads had 2.06" Intake and 1.72" exhaust valves. Rectangular port iron heads 1969 and earlier (not sure about 1970 and later) generally were 2.19" intake and 1.72" exhaust (My 1969 L72 with 3919840 iron heads had 2.19'/1.72" fwiw). Early 427 L88 Corvette with 3904392 aluminum heads had 2.19"/1.72", 3919842 aluminum heads had 2.19"/1.84" valve sizes and 1969 L88 and ZL1's with 3946074 heads were the first heads to have 2.19"/1.88" valves. What happened to these heads after they left the factory is anybody's guess and aftermarket heads are a totally different ball game. That's my experience.The typical factory stock Big Block Chevy 454cid cylinder head valve diameter size is 2.19" for the intake valves, and 1.88" for the exhaust valves. Of course aftermarket hi-perf aluminum heads offer those same size valves, but also a larger intake valve too, (such as 2.25" and even 2.30") for a power increase.
The factory BBC iron cylinder heads And the "conventional" aftermarket replacement cylinder heads from places like Brodix, Dart, AFR, etc. are 24 degree and 26 degree heads. All of which can be used with conventional factory and .off the shelf Big Block Chevy pistons. Then there are the big horsepower and big dollar BBC aftermarket heads that have different (flatter) valve angles such as 20 degree, 15 degree, 12, and even 9 degree intake valve angles, none of which can be used with conventional factory stock, nor off the shelf aftermarket pistons since they're all made for the conventional 24/26 degree BBC heads. Hopefully I haven't confused you.
But unless you have factory heads which have been brought to a machine shop and fitted with larger intake valves by a previous owner, then you have the 2.19" diameter intake valves and 1.88" diameter exhaust valves. And the heads are the typical BBC factory 24 degree intake valve angle design.
Back to your Qjet. Very likely replaced somewhere along the way with an stock off-the-shelf rebuild, which would likely have truck numbers. That's OK. I know one of the carbs Eric did for me was off a motor home ( from Tom mobely ) and the other maybe a md 70's something or other. The RV one is800+ cfm, while the 70s small block Camaro is a standard 750 cfm version.Honestly, I am really learning. This is what was wrote on the ad when I bought it. Any education you want to give me is much appreciated.
