1 - 8 of 8 Posts
i just put my new rear seat covers on. UPI. there is a small wrinkle in the seat back. it is not caused from over/under streching or having the cover on crossways. its a spot about 10" long in the middle of the pleated area. is there a fix for this? thanks Dave
Put a towel over the area, and give it a few quick passes over with an iron. Kind of like welding....Hit it a few short times, let it cool, try again, let it cool. Other wise you will melt it. This should take care of it.
You might just want to try a hair dryer. I've seen this tip before for smoothing out wrinkles in headliners and upholstery. This may also be less risky than the iron. But still need to be careful with any heat on vinyl.
Upholstery installers use a steamer to get the covers to fit right. I'd call a professional in the area and show it to him/her and get the right answer the first time before you damage the cover.
No way on vinyl..I've done all types of upholstery since 76. Steamers are used on fabric.
Good old outdoors is best on vinyl.
1 - 8 of 8 Posts
