Ok, I have the heads now. These are the ones from the auction at the beginning of this thread.
First off, these heads are far from being ready to assemble. The guides are .015 under and the seats are very wide. You could use a 2.250 intake valve if you want, but the seat IDs are cut straight down into the port and you would have no throat to seat transition blend angle/radius, I think a 2.300 would work best. I like the castings, but expect to spend quite a bit of cash at the machine shop to get them finished and ready to run, they are definantly only
simi finished.
The intake ports where advertized as 1.650 wide X 2.400 tall(std sqr port size). They are not. More like 1.800 wide X 2.100 tall. They will take quite a bit of port matching to fit a regular square port intake gasket. But there is plenty of meat to work with and will open up fine. And about an inch down the port the ports appear to get taller. Its looks like once the first inch of port is opened up to the gasket it will blend very nicely. I have a guess as to why they cast them this way
I guess I'll let yall know how they perform when we get them on the car and get to the track.
The picture shows(in order) a 781, this "Pro Race", an 074 and 990 head all stacked side to side.
And this one is a pic of the "Pro Race" chamber.
Not as fancy as some of the stuff some others on TC are running, but I think it will be interesting to see how they do.:beers:
