I plan to upgrade my fuel system with 1/2" lines and a new Mechanical Fuel Pump and a new Electric Fuel Pump.
It appears that the Edelbrock Victor Race Pump is the only Mechanical Pump available with 1/2" NPT ports. (please let me know if there are others).
I plan to install an Electric Fuel Pump at the rear to supply extra fuel when using Nitrous. I do not want to run the Electric Pump full time. The Electric Pump will only run when Nitrous is activated. I have heard too many stories about Electric Pumps noisy and failing and leaving you stranded. I want to use a Mechanical Pump as my primary pump for reliability and noise reasons.
I plan to run 1/2"(or #10) line to the Electric Pump and then 1/2" line to the Mechanical Pump. After the Mechanical Pump I will run two # 8 or # 6 lines. One to a return style regulator (1/2" line from regulator back to tank) and to the nitrous system. The other to a "deadhead" regulator and the carbs. The Nitrous side will be run at a higher fuel pressure.
I am considering the Edelbrock Victor Race Pump because it has 1/2" NPT ports. I don't want it to be a big restriction when the Electric Pump is trying to push fuel thru.
Will the Edelbrock Victor Race Fuel Pump be OK for extended street driving?
Thanks, Joel
PS. Please don't tell me I need to run two separate fuel systems. I have read extensively on the topic and WILL use the type of system I have described above. I just want to know if the Edelbrock Pump will be reliable for long term street use.
Thanks, Joel
