If you really need a crate motor,I'd go with the GM 454HO
if not,pick up a 454 core,do a search in the performance forum for the many,many documented 454 combos from mild to wild,and then find a competent machinist.
If you get good core,you'll only to need to do minor machine work,like bore the cylinders,recon the rods and cut the crank.This can all be done on a reasonable budget if you don't crazy with parts.You'd be more suprised at what you don't really need.
With that in mind,I built my 454 for $2500
stock oil pan,stock rods,stock untouched heads w/stamped rockers (other than valve job,new valves/springs) fresh bore/pistons and a mild hydraulic cam.
Fast enough for a fun,but almost stock looking musclecar
