The first problem is whenI turn on my headlights both of my turn signals come on in my dash.When the headlights are off they work fine. Ive checked my grounds,tried a new headlight swich and a new turn signal switch and still the problem ,By the way , are the side marker lights supposed to blink also when the blinkers are turned on?Another problem is I changed out my instrument cluster after this and now something is pulling enough juice from my battery and after turnig on my lights a couple of times there isn't enough volts to turn them on.I disconnected my neg. on my battery and put a test light in between and it barely comes on.Then I started disconnecting everything until I got to my fuses. I have a seperate fuse block for my elec. fans,msd,dist. and fuel pump and when I pulled the fuse for my dist. the test light went out.It's a mallory magnetic breakerless dist. Does anyone have any ideas why this would happen?
