I'm planning on putting the gauge type instrument cluster in my 68 SS & I have a couple of questions. I have the complete gauge cluster assembly & instrument harness down to the fuse box. I was planning on adding the wires I will need to the exsisting bulkhead connector on the firewall side. I'm not certain about the ammeter wiring. I looked at the Corvette diagram & here's my plan--extend the black/white wire from the bulkhead connector to the hot side of the horn relay, and run the black wire from the bulkhead connector to the junction block mounted on the radiator support. I'll use the orange fusible links at the ends of both of these wires. Will this work? If it won't can you tell me what I need to do? TIA
BL
BL
