1 - 2 of 2 Posts
Hi just wondering where the wire from the starter and coil should mount in the car is it to the steering column my chevelle had it mounted under the radio but someone ripped it out now i cannot find the other end of the wire. i can follow it from the starter all the way to the firewall then it was broken. any help would be appreciated
Are you referring to the purple wire from the solenoid/starter “S” terminal? That runs from the solenoid to the bulkhead connector near the brake booster. From the inside bulkhead connector it runs to the Neutral Start Switch on the top of the steering column under the dash. Color changes to a purple stripe there and runs up to the ignition switch.
1 - 2 of 2 Posts
