After 1 1/2 years of procrastination I have started on the project once again. I have been cleaning up the wiring harness under the hood and have come across a single orange wire coming out of the harness on the firewall without any connector on the end. I have researched several manuals and have inspected several other chevelles but still cannot trace to what it is suppose to connect to. The wire is 12 gauge.
I am hoping that someone out there might know to what I am referring.
signed "Lost without a clue." :confused
rick
Team Member
posted 03-23-2002 04:06 PM
kurt
Is it an A/C car? Sounds like the power wire to the A/C relay. Does the wire go thru the wiring gutter acrossed the top back of firewall? If so, it starts at the relay above the brake booster and goes to a fuse holder right where it exits the wiring gutter.
To get a better answer, you should post this in the electrical forum below.
Rick
72 El Camino
TPI 350/700r4
[This message has been edited by rick (edited 03-23-2002).]
72402kurt
posted 03-23-2002 05:40 PM
Thanks for your help but when I checked to see if it was the ac wire that was in place. It appears to have gone through the gutter on the firewall but I was mistaken with it being a 12 gauge wire. It is more like 14.
I will also post this in the electrical forum.
A #14 orange wire up there is for the blower motor. See if the other end looks like it goes back to the bulkhead connector. That's the way it hooks up for a non-A/C car.
If your car had heat only the wire in question would be for the blower motor. A car with A/C has a separate harness for the A/C components including the blower, in this case the orange wire is not used. It was typically cut off close to the main harness during assembly.
Elree Colby has it, the wire is cut off at the factory in a/c cars, documented in the factory assembly manual.
65 Danube Blue MALIBU 4 door wagon, 350/330hp crate with 700R4, Factory air, Factory am/fm stereo.
