Hey guys, 70 chevelle has the original column in it. The car was and original malibu with the 3 on the tree. The car is now a floor shift.
Since then I found a good condition steering column from a 68. Floor shift with all the knobs. problem is the ignition is on the dash. I am re wiring my car and if it's the only difference would make the swap.
What do you guys think?
Thanks for the help…
1970 chevelle
406 - TH-350 - soon to be 411's
406velle
2 yrs into a rebuild and still breaking things twice and fixing it on the third.
Me?? Opinion only. I won't do it. Believe the turn signal switch connector is different. Cut and replace. Need to cut into the ignition wires and add on older connector with about 3 feet of wire to a dash mounted switch. I like the fact that the newer columns somewhat hid the starter wires. Also like the locking wheel. Mechanically, will the column fit? I can't answer that.
Opinion again. I'd sell the older column and buy something newer.
are you only replacing the column to get rid of the ugly useless hole left over where the shift lever was?
<BLOCKQUOTE>quote:</font><HR>are you only replacing the column to get rid of the ugly useless hole left over where the shift lever was?<HR></BLOCKQUOTE>
Well that was part of the reason. The other part is I dont have the keys to the ignition on the column either. Also since the ignition was on the dash already I thought it would be an easy thing?
Thanks for the lead I'll check them out…
What kind of "newer" columns can I put in with minimal suspension alterations?
1970 chevelle
406velle
