1 - 2 of 2 Posts
'69 chevelle BB
Wire from harness to coil connection is getting warm when the switch is on (even if not starting, or engine is off).
There is a splice at the point of the heat, but should it be getting warm?
I've got another post concerning proper grounding points. Can this issue be related?
Other?
If the splice is loose, it will generate heat. Also, the resistor wire may generate some heat as it dissipates voltage.
My Web Page (updated 11-22-02)
"Long Live Freedom!"
Chad Landry
TC Member #643
ACES Member #4556
'68 El Camino
1 - 2 of 2 Posts
