I installed a tilt column from a 1986 camaro in my 66 chevelle. It took a little modification but it turned out nice. Is there a way to wire the wiper switch from column to my wiper motor. I found a wiring diagram of the switch. It has five wires (white, gray, green, purple, & pink. It shows the white wire going to the fuse box. The rest are shown going to the wiper motor. I connected the white wire to the fuse box, turned on the ignition and checked the other wires. The results were:
1)Gray...12v in wash, delay, lo-speed
2)Green..12v in off, wash, & lo-speed
3)Purple.12v in Hi-Speed
4)pink...12v in all positions
If it is not possible, does anyone know of a wiper motor that will work and bolt in?
