1 - 10 of 10 Posts
Have a 70 chevelle with hidden wipers, motor was bad so changed it with rebuilt from autozone. Seems to run on high in low position and low in high position. Also will not shut off and park without turning keyswitch on and off. Have looked at different sites for new switch but could only find one without hidden wipers. Whats the difference?
jim70
Discussion Starter #3
I found it, I found it!!! Thanks a lot John for the info. The link to Elree's info with the drawing did the trick. I finally realized that I didn't have a ground on the switch itself. Guess I took it off when I had the dash out. Didn't see a ground showing on the electrical prints unless I overlooked it which is possible. Thanks again for the info, even made my wife come see. Ha- jim70
I have been having problems with my wipers also. Sounds like it must be a grounding problem. But I keep reading about Elree's info and drwing that is supposed to be located at http://www.chevelles.com/forum/Forum22/HTML/002207.html, but I get an error 404 when I try to go there. I know some of the messages are old, but does anyone have the correct site link, or the info that was in it?
Well, I don't believe the hidden and un-hidden switches are the same. I tried a new unhidden switch on my '69 and it did some very weird things.
Well OK. Usually some of the weird stuff happens when the switch isn't grounded.
The wipers work on a ground system, unlike most switchs,They must have a good ground.Good Luck.
1 - 10 of 10 Posts
