Okay, this is the wiper motor on the truck, but I use the truck to haul the Chevelle (just to keep this Chevelle related).
1. the switch: 10 ohms between the terminals when the switches are on. No problem.
2. the motor: 10 ohms between all the terminals that power the motor and 10 ohms between the terminals on the washer pump. No problem.
3. the wiring: 10 ohms from switch-end wire terminals to motor-end wire terminals (light blue to light blue, dark blue to dark blue and black to black). No problem.
4. the wiper arm mechanism: all free moving with no binding. Even with the mechanism disconnected the same problems (see below) exist.
Problem: when I turn on the switch the motor won't move. The fuse is not blown. If I turn on the wipers to high (two-speed) and help them get started by hand they barely keep moving and usually stop after a few wipes. The low setting will not move them at all. Pushing the washer motor switch while turning on the motor switch will usually get them moving by themselves but they stop when the washer stops.
The motor is rebuilt-new about a year and a half ago. It's been getting steadily weaker. I hooked the motor up directly to the battery and it ran for a few turns and then stopped. No more direct current would get it started again even with a push. I can still get a ohms reading through the terminals.
The motor is also fed with yellow wires which I have not traced to check their continuity and they don't go to the switch. Everything has a good ground.
What am I missing? What could be causing the problem?
NCOA member #220 ACES member #1670
Team Chevelle #998 YesterYears Chevys #52949
American Muscle Car Association #142
Rich's 1965 Malibu SS Restoration Project Progress Page
President, Heartland Chevelle Club
http://heartland.chevelles.net
