1 - 2 of 2 Posts
My windshied washers come on everytime I turn the wipers on and continue run. is there a problem with the switch or do I have a wire in the wriong place????
Pull the 2 lead wire plug from the washer pump see if it continues.
Cam and timing is probably just out of synch,
turn on washers and then pull the plug it should cancel within a few pumps.if not you'll have to pop thecover off and check the relay and cam.
1 - 2 of 2 Posts
