1 - 8 of 8 Posts
I'm about to order some replacement vinyl. What should I use to glue this stuff on? Any tricks of the trade I should know about before I attempt this project?
I,m no expert but I used regular upholstery adheasive. Worked fine.
I went to Joanne Fabric and picked up fabric and adhesive that is good for fabric & metal. Do a search on this topic - we have discussed this in previous threads.
PS Be careful - I went back the next day after replacing the SS trim and the windshield was cracked. Typical project goes from $10 to $250 in a heartbeat. LOL
I don't have the vinyl yet, but did you have to do any fancy folding or cutting to get the corners to tuck in?
I did thats how I learned about legendary auto interiors to get teh vinyl.
Its pretty easy - You will need to cut into the corners at a 45 deg angle to help fold around curves. The material stretches pretty easy. I started from the middle by taping the material down to the windshield and the frame and then worked my way out to the end, let the glue set up and then took the tape off and worked to the other end. I trimmed everything up with scissors and Xacto knife after the glue dried. Hope that makes sense.
1 - 8 of 8 Posts
