The gear inside the door on my 69 must have several broken teeth. How do you remove this assembly? Symptom: Window rolls up a bit then stops and the crank has no resistance, then it grabs again and the window goes up some more; repeat until the window is up or down.
Redrum (or Mike)
68 Corvette - 383 CI 427 HP
69 SS Chevelle being updated to Pro-Touring
97 Z-28
Redrum (or Mike)
97 Z-28
