Just got done welding/grinding/painting the front channel. Tell me what you think!!!! This took me all today to finish. Better than before though.
This was actually pretty easy to do. I find myself more terrified doing other things on the car. First step was to get a cutoff wheel for the angle grinder then cut right along where the channel bends. Then cut off the lower section where the spot welds are at(had to drill all those out and that was a pain) The air chisel help get the stubborn ones out. Then ground off all the rust and treat with metal etch and then slapped a quick coat of epoxy under the piece that was welded.
In with the new metal. Use Screws to hold it down and spot weld every other hole. Wait for panel to cool and then tack the piece every 10-12in to make sure it didn't warp, then fill in between the holes. Take the angle grinder and grind everything down, making long sweeping passes to make sure it keeps a nice smooth edge. Finished up with a long flat file and a quick coat of epoxy. Next will be to apply some filler along the edge to make a perfect bend.
Before:
During
Before:
During
