1 - 9 of 9 Posts
Hello, everybody.
I have a few questions regarding a 496 I've built for boost. I've changed my mind about the boost application, and until I decide, I'm curious how the motor will run with a blower cam and pistons gapped for boost until the supercharger is installed. I'd rather not tear apart the engine to swap out pistons/rings/cam down the road when I slap on the blower.
It's a freshly machined 496 forged internals and stock rebuilt 781 heads. I have Malhle pistons (#929869510) and I gapped the top at .026 and second at .028. These pistons and Eagle stroker kit yield about 8.5:1 compression.
Will I have any issues running these pistons with these ring gaps until boosted? Will I have excessive blow-by? Will the engine be a complete dog at 8.5:1 comp? I have a turbo 400 and will be going with a 2200 stall converter, 3.55 gears, and a Gear Vendors overdrive.
Thanks.
· Super Moderator
Pyro,
I was mainly replying to the blowby part of your question. Obviously the engine is not going to be that great at 8.5 to 1 compression with the wrong cam but with 496 cu in you might not notice it that much :)
Blower cam?
What is a blower cam? There ought to be lift and duration specs, and I'd bet they're really quite tame.
You shouldn't have any problem. I ran my car for several years with a "blower cam". I ran it with 14:1 compression and a small shot of nitrous. The rings were gapped for nitrous. Nitrous and blower cams are very similar. When I finally went to the blower I changed the rotating assembly because the crank needed a BBC snout and double keyways to drive the blower. Plus the compression was reduced to 10:1.
Hello, everybody.
Thanks.
8:1 being a dog?, better tell that to my BBC that run some great numbers, but the cam you have for a boosted application could make the power in the higher RPM range not what you want with a low compression BBC.
1 - 9 of 9 Posts
